Use this command to show the remote-endpoints that have been created.
| vn_name | Display remote endpoints only for the specified Virtual Network string. |
| vni | A unique 24-bit Virtual Network Identifier that is used in the VXLAN header to encapsulate tenant frames. |
| vni | Virtual Network Identifier value between 1 and 16777215. |
| ipaddress | IP address of the remote endpoint. |
| ipaddress | A remote endpoint IP address |
N/A.
When no VXLAN name or VNI is specified a summary output of all remote endpoints appears. You need to supply the virtual network name or VXLAN VNI to query the remote endpoints associated to a specific virtual network. To display detailed information about a specific remote-endpoint, use the ipaddress option.
# show virtual-network remote-endpoint vxlan
IP Address Virtual Router Next Hops Virtual Active/Total Networks
200.1.1.1 VR-Default 2/2 2
200.1.1.2 VR-Default 2/2 1
200.1.1.3 VR-Default 2/2 1
200.1.1.4 VR-Default 2/2 1
200.200.200.200 VR-Default 0/0 0
Total number of Remote Endpoints : 5
# show virtual-network vxlan
remote-endpoint ipaddress 3.3.3.3
IP Address : 3.3.3.3 VRF : VR-Default
Learning : Enabled Stats Monitor : On
Health Check : None
== Next Hop Information ==
Gateway : 22.0.0.1 MAC : 00:04:96:97:f8:a6
Interface : trunk2 Port : 1:41
== End Next Hop Information ==
== Virtual Network Associations ==
Virtual Network : vni1 VNI : 1
Origin : OSPF Learned,
Virtual Network : vni2 VNI : 2
== End Virtual Network Associations ==
# show virtual-network remote-endpoint vxlan ipaddress 100.1.1.1
IP Address : 100.1.1.1 VRF : VR-Default
Admin State : Enabled
Learning : Enabled Stats Monitor : Off
Gateway : 50.50.50.1 MAC : 00:04:96:9a:92:b7
Interface : s1 Port : 1:45
Virtual Network : vn1 VNI : 1
This command was first available in ExtremeXOS 21.1.
Information about the remote endpoint's administrative state was added in ExtremeXOS 22.4.
This command is available on all Universal switches and stacks supported in this document.
